HoytAdickes
Thread starter- Joined
- May 24, 2019
- 22
look at your carb too. if you have no fuel squirting, you have no fuel in the bowl.
since your fuel pump is squirting fuel, check your fuel pump pressure. it should be 4-7 psi. however your float could be messed up. should be a holley 2-barrel. about the easiest carb in the world to work on. one touch simpler than a kohler toilet.
my guess is you have crud in the bowl plugging up the accelerator pump circuit.
Thank you. I'm leaning towards carb rebuild as well.
