ShoestringMariner
- Joined
- Apr 18, 2015
- 1,605
Update: had a productive weekend. Transom is in. Not perfect. I had another issue with the motor well tubes. I forgot to include the thickness of the transom skin when I cut them to size. I thought I’d try it anyway. It’s got a slightly flared opening on the motor well side. I had another that wasn’t cut down yet, so I got that one right. I’ve ordered another to replace the one that is too shallow.
the exterior of the transom is sanded and primed with Etching Primer. Not sure what I’m going to do about the heavy pitting below the waterline. Using Water Weld or Marine Tex seems like a LOT of work. Wouldn’t a light automotive spot putty work considering it will be sealed under paint?
I’m still debating whether to use this PPG ALK200 that I have on hand. This is a trailered boat but it could be in the water for a week at a time a few times per year.
Next up is installing the CMC and new rearmost floor section which has been treated with the OTF everyone is talking about here. I think I will also strip and repaint the splash-well before reassembly
