ShoestringMariner
Thread starter- Joined
- Apr 18, 2015
- 1,605
Well, still not much to show. Couldn’t get to it for 2 weeks. Did a leak test at the lake and found a broken rivet. At a nasty dent near the keel. It terminated at a rib, slightly deforming the rib. It was a relatively fast leak and I’m sure the prime culprit of my leak woes. Dry everywhere else. Because I couldn’t bang out the damage, I left it. I used stainless pan head screw and a nylock nut with 3m 5200 on this instead of rivets.
And, finally got the underfloor Styro SM installed along with the rear floor, each piece glued to the next with foam board adhesive. I put Styro 12” up the hull and clad it in aluminum. I wasn’t going to mess around making it form fit to the transom as nobody is going to look under there anyway.
I remade the door jambs as the originals were beat and broken. They ended up wider as my brake couldn’t do double flanges so close together.
tomorrows work is reinstalling the splashwell, final paint and motor installation. Found some bad wiring on the CMC that I need to replace. I hope my steering cable and controls will work with the CMC setback. Install seats and new hull numbers
