Nissan 9.9 conversion
Capten
Hello. New to the forum and researching an outboard I have. I have a nissan ns9.9b serial 97878 which Tohatsu says is an ‘87. Is it possible to just do the cam swap on this unit to upgrade to 15hp. Does anything else have to be done?
Capten
Do you know where the best place to order that cam. I tried searching by part number but the few spots I found said it was for a mid 2000’s Nissan
Capten
Also pardon my newness. First boat and outboard but does the prop need to be changed ?
pvanv
Year is irrelevant when servicing Tohatsu/Nissan OBs. Model/serial is everything. Proper propping has nothing to do with HP. You might be able to increate pitch a hair, but only with a tachometer would you know. PM me for help getting the part.
Sea Rider
After the cam swap, with motor OFF full throttle the throttle grip and check if carn butterfly opens fully, if so, will need to check the time advance is correct as both 9.9 and 15 HP have different factory settings or won't perform as a 15 no matter if the cam has been swaped.
Which boat model and how many passengers onboard do you plan going boating with ? to determine if in need of a prop maximization from current factory delivered one.
Happy Boating
Capten
It is a 16’ aluminum springbok. 3 adults with hunting decoys and equipment would be max load setup. Less of a load when fishing.
Sea Rider
Start by ordering the mew cam and proceed to change it . Let us know when it's done. With cam swap butterfly will open more consequently delivering more fuel imput which meeds more time advance adjustment. Do you know how to check the time advance on those 9.9 motors ?
Happy Boating
Capten
I do not know how to check time advance I’ll order the part and Get the ball rolling
Sea Rider
If possible post a clear pic of right motor side showing the throttle mechanism, time advance plate. Stand in middle of motor when taking the pic.
Happy Boating
