Installing 23-847637 Mercruiser bushing
tank1949
My Bravo 1 needs bushings where gimbal hinge pins are located. MC calls these Trim sender bushings, which made it difficult for me to find. I kept searching for hinge pin bushings. Nonetheless, how are these bushings installed?
Bt Doctur
if you mean part # 41721 a thin round disc reddish in color .You remove the hinge pin,insert it between the housing and steering yoke , reinstall hinge pin
Bt Doctur
OK , looked up that part number, you need to completely disassemble the steering yoke , manual link coming
tank1949
once you have it apart install that missing gearcase fitting too
this section http://www.boatfix.com/merc/Servmanl/11/11b4r5x.pdf
page 4b-6 #3 "bushing" of above www.boatfix. Hinge pin's (covered up by trim sender/limit switches) bearing part goes into this . This bushing is NOT part of steering. And, yes I AGREE it can get confusing with all these bushings. Thx... I could use large C clamp to act as a press. I guess just pick out the old ones with pocket knife?
Bt Doctur
now this is a bit confusing what is threaded to retain the hinge pin
Fun Times
Page 4B-21 shows you how to remove the bushing and Page 4B-22 & 23 suggest using a press and special tools from Merc to reinstall the bushings.
Bt Doctur
is this a bravo Hi Performance that uses 2 bolts to secure the hinge pin
Fun Times
Bt Doc, On standard hinge pins the bell housing holds the threads for the pins to screw into.
On High Performance hinge pins the bell housing holds a smooth but tight bushing # 23-847637 so the smooth hinge pin can be slide hammered into the smooth bell housing bushing....The high performance gimbal ring doesn't hold a smooth bushing as the ring is sized from merc to fit the H-P smooth hinge pin...(That I recall)...,But the bushings are all the same part numbers 23-847637 that fit into the non threaded H-P bell housing or standard gimbal ring as again the standard bell housing is threaded.
In here see both bell housings item number 1's and hover your mouse cursor over the notes for details then see bushing item number 6 and it's note too..., https://www.mercruiserparts.com/bam/...30967/1943/180
In here for the H-P ring, see the second set of item number 1 down the list of parts and see items 10 and 11 and notice no bushing item number 3 (23-847637) listed like in the first set of part numbers of item # 1, https://www.mercruiserparts.com/bam/...30967/1943/170
https://www.ebay.com/sch/i.html?_fro...74A17&_sacat=0
https://www.ebay.com/sch/i.html?_fro...odkw=822374A17
tank1949
Manual calls for special too to press in bushing. I should be able to use large c clamp as a press. RTHX!
