Oil monitor hose to bell housing
metsfan3197843
Finishing up transom kit rebuild and only have the oil hose to bell housing connection left, it’s kicking my butt. Any tips? I have not driven the uni bellow sleeve on yet so I can pull the bellows out of the bell housing. Not sure if that will help ant though....just a blind stab with a tight connection in a bad spot. I’m sure I should have done things in a different order
Bt Doctur
you are correct in the assembly order. Being VERY careful not to break off the plastic barb you need to:
slip the bellow off the gimbal side , remove the hinge pins, pull gimbal rearward, and you should see the brass barbed fitting .working with needle nose from inside the gimbal force fitting onto barb and ty-wrap it
Put ty-wrap on the brass fitting real loose before installing hose. I use full strength dawn soap n the hose
metsfan3197843
Thanks guys. Removing the uni bellows from the bell housing was the ticket. Sometimes you got to step back after a long day and regroup. First time doing all this. Wasn’t too bad of a job. Oil hose was definitely the most challenging part. I believe I got the uni bellows retaining ring in properly. Can someone take a look at my picture and tell me if it looks good please
thanks!!!
Don't see the lube tube, but everything in the pic looks good from my side
metsfan3197843
Thanks, sorry just wanted a second set of eyes on the retaining sleeve. Really appreciate all the help from everyone on here.
