correction - max RPM under normal load.
as said above: Smaller motors react more to pitch changes than larger motors.
buy yourself a tiny tach and set it up and find out what RPM you’re actually getting before doing any changes.
But: prop shops normally will go +/- 2 pitch on a prop. So if you are getting near 6k on a 5-6k max RPM and 5.5 is the sweet spot, go ahead and have it refurbed +2 shouldn’t hurt too much. But you need accurate numbers first.
Thanks for thre info.As I new my rpm reading due yo installing tach last year.
