Dentpusher
Thread starter- Joined
- Sep 11, 2017
- 12
Background. Engine has really never run perfect, it's always been a bit "lopey" @ fast idle and an occasional "lean sneeze" since I bought the boat in 2000 (a mechanic early on said that the sneeze was HARD to fix and suggested living with the sneeze), EXCEPT for one week, 2 summers ago. I had done my annual decarb with Berryman's instead of Seafoam and the thing ran GREAT all week. We get back down to the lake a couple weeks later for a weekend and it's running as usual again. Then last summer it ran similar, on our last weekend out until I could definitely feel a miss even underway for the first time ever and it would not rev normally like it usually does. Now I am trying to diagnose. Cold compression test revealed 95 in #6, 105 in #1 and 100 in the other 4 cylinders (lower than what I would like but no visible scuffing and cross hatching is still visible with a scope). I had some of the cheap "in line" spark testers and found #1 cylinder had WEAK visible spark so I swapped 1&3 coils and the weakness stayed on #1 so I have put it through some paces since it seemed to be more involved than the ignition coil.
I acquired an OE manual on top of my SELOC ( hate that thing ) and grabbed my multi-meter. I jumped to the flow chart and went to "No Spark on One Cylinder" and went to STEP 4. My charge coils were 120V each side but passed the resistance and ground tests. STEP 5 - Sensor coil passed the Ground Test. On the Output Test #13 I got P - .194, .183,.186 S - .193, .195, .187. On test #14, P- .852, .251, 1.021 S- 1.015, .940, 1.066. Testing resistance in Sensor Coil #16, I got readings of between 350 for the low, 2@357 on P side and 2@365 to 382 Ohms on Starboard, with my Chinese "Fluke" meter. Test #17 was 233 Ohms and there was no ground in test #18.
With the poor results I had received so far, pointing to something in the Stator, Timer base or flywheel, I wanted to confirm how poor of spark I had so I got a couple, more sophisticated, adjustable spark testers and set them to 7/16 of an inch, as suggested in some of the other threads, and found weak, intermittent spark just about everywhere at that setting, hardly any sharp snapping, blue arcing at all while cranking with the other plugs disconnected.
I am preparing to pull the flywheel. What would the gurus here look for? Are there any other tests I should do before firing the parts cannon? Will a DVA make a difference in any of my readings (my meter has built in Min/Max button)?
PS: I had a new Stator put on about 10 years ago for overcharging condition. I understand it could be bad now too, especially since I just found out how bad it was to run with wing nuts on the main battery. This is a clean looking, fresh water only motor. I have seen some ugly, crusty stuff in photos online and mine looks nothing like those salty things.
Thanks in Advance!
Edit: I'm a believer in OE parts but curious if CDI makes good aftermarket stuff (like MOOG). The optional 5 year warranty is appealing if they make quality stuff.
Thanks in Advance!
