CLi87
Thread starter- Joined
- Sep 21, 2018
- 237
Hi there everyone, I bought a (new to me) 92' Bayliner 2252 with the Mercruiser 4.3 paired to an Alpha one outdrive. The boat has been sitting under covered storage for roughly 10 years, only 292 hours total on the boat though. I checked the engine oil which looked old, but no rust or water from what I can tell, also used a scope to check the cylinders as best I could and the pistons look fine from what I can see, just some surface rust on the cylinder walls. I figured there would be some rust and corrosion so I sprayed in some Wurth Rost Off Max Ice and left it for a day, tried turning the crank by hand and using a rope but nothing, so I completely filled the cylinders with 50/50 ATF/acetone mix and let it sit for another day, still wasn't able to move the crank by hand and I don't have a special GM crank tool, so decided to throw some fresh batteries in and give her a crank to see if I could break the pistons free. Each time I crank, I see the pulley move about half an inch, and I did this 10-15 times and the crank pulley kept slowing moving forward, so I assume the engine isn't completely seized otherwise it shouldn't move at all.
Has anyone been in a similar situation and what do you guys use to move the crank? I'm a BMW technician so I'm familiar with motors in general, just fairly new to marine motors and the GM 4.3.
