Picked up a 2007 Larson with twin Mercruiser 5.0 MPI Bravo III. Fired both engines up and went for a slow drive and within 20 minutes the port engine died. It will crank but it will not start. Made it back on one engine and when I got to the dock, I waited and it started normally again. I left it running and within 20 minutes it turned off again. Bottom line is that if I let it cool down a bit it will start again but around 20 minutes it dies.
Swapped IACs, fuel pump relays, took off top of carb, and everything looked as it should. Thinking it may be that the fuel tank wasn't breathing, I took off the fill cap, and no help. One thing to note is that the starboard engine sounds the alarm when key it turned to run, as it should, but there is not sound from the alarm on the port engine...the one I'm having problems with. My guess is that the buzzer is bad on that engine.
When I start the starboard, I hear the alarm, fuel pump relay and a very noticeable fuel pump fizz. On the port engine, no alarm, I do hear the fuel pump relay, and the fuel pump has the fizz but not as loud as the other engine. I really don't think its the fuel pump since I've only seen them go bad and not work again. It appears it's a sensor heating up.
I didn't have a whole lot of time and left it at the marina, which is 4 hours away. I should have checked for spark when it wouldn't run, but was so stressed it didn't cross my mind.
I'm guessing if no spark, it could be the hall sensor, ignition coil, or maybe even the magnets on the distributor itself. Am I on the right track? I purchase the techmate pro, but won't come in until later this week. I won't be able to drive down to the marina this week, so I will be forced to call a mechanic to get it fixed. I have to move the boat from southern FL to the central East cost this weekend.
BTW, all gauges show correct oil pressure, temperature, voltage, idle when running, and fuel tanks are full.
I would like to get the service manual but not sure which one I need for this particular model. I've narrowed it down to #24 or #31.
