1969 Johnson 6R69M Lower Unit Leak.
cprodave
While repairing Lower Unit for milky gear oil I discovered the Prop Shaft has in-and-out play of about 2mm. The run-out is near-zero, i.e. no bent Prop Shaft. Is this in-and-out play normal vs. indicative of bad Thrust Washer, etc? The Gear Oil Fill Plugs seem ok although the washers on Plugs are clearly not original (mechanic probably replaced washers a couple years ago while changing Water Pump). I appreciate any input/advice.
F_R
2mm, eh? That doesn't sound too bad. Can we assume the big bushing on the forward gear isn't trashed from running with water in the oil? Make sure there is a thrust washer at both ends of the splined section, and run it.
When you had the lower unit apart did you find the 2 thrust washers??----What did the forward gear bearing look like ?
cprodave
Sorry for delay, going to be another day or two until I can get back working on this...
cprodave
Update: of the 6 Gearcase Screws (p/n 304071) holding the two castings of the Gearcase (p/n 390040) together I was able to loosen 1 screw. The other 5 screws seem to be seized. I tried a heat gun but no luck. A couple questions: 1) is it feasible to use a propane torch or will I likely melt/damage the seal between 2 Gearcase halves (or even damage internal gearcase seals 2) does the bushing in the propeller need to press tightly against the Gearcase O-ring p/n 303360 in order to get a tight seal? 5 years ago I replaced the stock 2-blade Propeller (due to a Spun Prop which my local PropShop said could not be " rebushinged") with a Michigan Match 3-blade p/n 012008 8-1/4" x 8" RH. Outboard has run fine with that prop, although there is some weird possible pitting/corrosion on the Gearcase near the prop. However, inside surface of the 3-blad Prop still has original paint intact, so I know inside of the prop is not rubbing the Gearcase. (I can't find original Prop, it is hiding in my workshop somewhere--or may have been lost in hurricane past September). What could be causing this pitting? Outboard has no zincs by-design (real Old School--1969). I will post a photo separately (phone camera vs. Laptop issues...) 4) if Gearcase Lube hasn't been changed in 5 years or longer, is it possible/normal for milky condition to eventually occur? If the Water Pump on this model can be changed (which it was, 5 years ago) without draining the Gearcase Lube, then the Lube in this outboard could have been well over 5 years old. Thanks in advance for any advice.
50 tears ago we used an impact screw driver to get those out.-----And it is NOT normal for water to eventually get in.-----Do not forget to change the shift rod O-ring !
F_R
Sorry, I disagree. I say it is normal for trace amounts of water to get in over a long period of time. That's why the owner's manual says to change the oil as part of normal maintenance.
Those screws will come out with ease with a hand impact screwdriver.
How much is a " trace amount "-in this case ?-------I say lower units are sealed and no water gets in !
Tim Frank
Agreed....with the caveat that it does depend on what constitutes a "trace"....and the period of time involved.
Five years? :eek:
If that long, I would say all bets are off and I agree with FR.
In this case, I would be inclined to just flush and fill the gearbox and check again after a week or two of use.
If oil is clear and water-free, keep on boating....and change oil at end of season as part of regular routine winterisation.
cprodave
Thanks to all for the input. yes I did use a hand impact driver--that is how I got the 1 (of 6) screws to loosen. I too am afraid that all bets are off. So I am going to go with Tim Franks' advice and will let you all know status in a couple weeks.
Thanks again.
These lower units are precision built.----Therefor easy to maintain / repair.-----But yes many owners today run their lawnmovers / outboards till they go " boom " then it is cheap to go and buy a new one.
