mcgreavster
Thread starter- Joined
- Feb 27, 2017
- 58
Went to jump on plane this morning and 10 seconds after taking off my motor died, primer bulb was completely empty. Re primed the ball and took off again and the same thing happened, and again and again. I started idling back to the ramp and the motor would die every 20-30 seconds. Eventually just started running back and pressing primer bulb as motor was about to die and I could run it without it shutting off on me. My boat has two gas tanks and I had this issue while trying out both tanks so I don’t think it has anything to do with the tanks (the problem would have to be from the tank selector valve to the carbs im assuming ?).
I’ve noticed almost all year after putting the boat away in garage I have a oil/gas streak coming out of the port side cowling and running down the motor, is this normal? I also noticed today when I would run back to re prime the bulb it looked like gas in the water (I popped cowling off and couldnt see any super obvious leaks while it was running).
Anyway I’m thinking it has to be either a bad leak or my fuel pump is bad. I have the original VRO pump but I premix now. Is there any good ways to test this pump to see if it’s the problem?
Thanks
Thanks
