Renken1600
Thread starter- Joined
- Feb 10, 2019
- 46
Hey guys,
Just fired up my 89 Mercury 115 2 stroke. Had the muffs on it with medium pressure as per the directions and fired it up.
I had just finished putting a new water pump and impeller in the engine so I checked to see if I could get it in gear. Moves forward and reverse no problem.
Problem is... I see no water coming out of the tell-tale. I'm not sure if it is supposed to be coming out instantly with the muffs or in the water? I will try and follow the route of the hose and see if the hose is blocked... after that I need some help as to where to look. New to the outboard motor world.
Cheers!
Cheers!
