bblagonic
Thread starter- Joined
- Jul 19, 2019
- 19
Hello to all,
My colleague is having a problem with his Tohatsu 30hp, 2 stroke, engine.
The problem is that while reaching certain boat speed (abt. 10 kts), the engine starts to overrev.
However, he states that once the boat with the same engine used to work normally and reach 19kts!
Following has been checked:
1. The prop hub is good,
2. Gears and clutches...all good.
3. The engine has been tested in the workshop with load on complete range of rpms...all good.
4. The antiventilation plate is on the level of the bottom of the hull (not on the bottom of the keel)
5. Fins have been installed on the antiventiation plate but the problem persisted. (Fins are removed now.)
6. Different mounting heights of the engine have been tested as well as the trim angles. The problem is always there.
Facts:
1.The hull is a semiplaning type with long and wide keel (keel height is 6inches while the thickness is 4inches). However, the keel is slightly rouned and narrowed last 4 inches before the prop.
2.The keel is really wide for my opinion. 4 inches of keel versus 9.9 inches of three bladed prop diamater.
3. Engine cooling system use to have problems and a lot of soil deposits. (The water intakes are on the same level as the keel and I suppose that beacuse of being in keel's shadow, a lot of air is cooming on the intake port.
4. Starting from zero speed, the boat and the engine interacts weel, the engine is gaining roms and boat the speed but at certain boat speed the egines starts to overrev and there is no and gain of boat speed.
Possible corrections:
1. Remove part of the keel...abt.20inches...on the boat aft
2. Try with XXL engine leg in order to have the prop and the water intake bellow the top of the keel.
3. Try the engine brackets moving the engine from the transom for abt. 10 inches aft.
I know that it is confusing that everything worked normally with the same hull and the engine but all has been tested so far and the only thing to try now is to do something with the hydrodynamic. (The only problem that is present from the day one of this boat is poor cooling performance of the engine which I suppose is due to the bad position of the water intake sucking the water in the keel's shadow.)
Any ideas?
Few photos are attached.
Thanks!
Bojan
Facts:
Any ideas?
Thanks!
Bojan
