Mercruiser 165 L6, Fuel pump leaking fuel.
ttownthomas
I'm in the process of nursing these 165's back to health. I have replaced the manifolds and risers, cleaned the carbs and finally got the stbd motor running without leaking water. The lack of water allowed me to notice a very large fuel leak. I was planning to replace the fuel lines and all components back to the tank anyway. My question is this: someone replaced the hard fuel line from the pump to the carburetor with a hose. It looks sloppy and dangerously unsupported that way to me. I am inclined to cut and flare a new piece of tubing but Im not sure where to start with figuring out the right hardware and flare types. I have flared brake lines before. I'm assuming that it would use a double flare and some sort of NPT thread?
Its a rochester 2 jet and a mechanical fuel pump.
The nipple going into the pump should be 1/4 npt, and break line works good with double flare.
Bt Doctur
5/16 steel brake line worked for me from the pump,out 2 inches 90 up, above valve cover 90 over, then 90 to carb.
If you do brake lines you can make fuel lines
kenny nunez
From the location of the fuel pump the engine appears to be a 292 rather than the original 250. If they are both running good that is a real plus for the overall performance. Check for excess play on the distributor rotor shafts, if so get the distributors rebuilt.
ttownthomas
How can you tell if its a 292 vs a 250?
ttownthomas
Here is an overall shot of the engine. 292?
