justthisguyyaknow
Thread starter- Joined
- Jul 13, 2009
- 38
73 Starcraft with a 120hp 4cyl, and a pre-alpha sterndrive. I was in the water ready to ski, and my daughter had trouble starting it. I said give it a little gas when you start it.
Well, she proceeded to start it and immediately PUT IT INTO GEAR while it was still at a rather high rpm.
Surprisingly, the boat pulled me up on skis. Unsurprisingly, it stopped after about 2-3 seconds.
I got towed back in (I owe someone a case of beer), and back at the house have found:
1. While the engine runs, the impeller apparently isn't turning (no water is being pumped)
I then removed the outdrive and found:
2. Metal shavings in the grease around the engine coupler.
3. Moderate spline damage on the input shaft (not sure what it's called, but the driveshaft going from the engine coupler to the top half of the outdrive).
4. I found that turning the prop does turn the input shaft, and that forward/neutral/reverse does work.
5. Turning the input shaft, even in neutral, results in a horrendous noise from the lower section of the outdrive.
Now, in my mind this points to two independent problems, both damage to the lower half (the noise I'm hearing), and also damage at the engine coupler.
I'm beginning to question whether the boat is worth it if I have to pull the engine (which is tedious), replace the coupler, and rebuild the outdrive. Not to mention a bellows job and new shift cable which I'm at it.
I'm open to any opinions as to the best course of action at this point.
