merc 40hp 4cyl pumping water but still overheating
rdp48386
i have a 40hp merc ser # 0G012622, we replaced the water pump and impeller, it pumped water after a minute but the idle was high. we shut it off and adjusted the idle, it got really hot amd an overheat warning horn. also didnt pump out the pee hole again. any ideas?
jimmbo
Were you on the hose-muffs, in a barrel? Stuck thermostat.
jimmbo
It peed the first time it ran but not the second time?
jimmbo
You have to submerge the water pump 3 or 4(some say 6) inches to get it primed, it is located at the top of the gearcase housing,
jimmbo
The split has to be at least 4 inches below the surface of the water
