Hidden horn diagnoses
garbageguy
The little electric "hidden horn" on 1998 Wellcraft 240SE was weak when I got the boat about 7 yrs ago. Since last yr, no sound at all. Assuming the little horn reached end-of-life, bought a replacement Attwood horn for about $10. Before removing old horn, pulled wires, getting 12-volts through the wiring when switch on dash is rocked on. Put the wires to the new horn, got a little sound - figured the temporary test connection not so good. Before I remove old/install new horn, I want to make sure the new horn works - should it sound if it gets 12 volts, maybe a quick touch of the 2 wires to a known 12-volt source?
It should sound, but also always check the ground. A bad ground will reduce output
garbageguy
Thanks AD, that's what I wanted to confirm. Yes, a good ground is key.
Before I take out the existing horn, and installing new horn, I will make sure ground is real good
to test new horn
open the hood of your truck.
black wire goes to - terminal on your battery
red wire goes to + terminal on your battery
you may poop yourself when the horn sounds.
then chase the wiring on your boat.
Grub54891
Doubt it, its a boat horn, most not very load at all of that kind
Sorry garbageguy for getting off topic, but the small attwood horns are not a air horn. The one on my Formula is a air powered horn and real loud, but the Rinker is a Me Me little thing and doesn't do much either
garbageguy
Thanks for the input (and funny pic). Off-topic is fine, it's all good info from you good people.
I used to think I'd put an air horn on the boat - but there's so many other things to do...
I have a hand-held air horn if I really need it - but have never had to use any horn on this boat in this water in 7 yrs - so just a working meep/meep horn activated from the dash switch is all I'm looking for at this point.
Can I expect to be pulling the exterior plastic cover plate, off the bow to access the horn, by using a utility knife to slip in there and pull it off, replace the little horn, then stick the cover back on the bow exterior with some type of adhesive? Seems a lot easier to get at it that way than by going through the anchor locker access in the bow of the cabin?
careful with the hand-held air horns like the ones on-sale at Walmart and worst marine. in the heat the can will rupture. I kept mine in the drink holder for years, then one day it shot up in the air about 5 feet
regarding access to the horn, I believe the cover is simply a grill over the hole. most likely you will need to dig your way to the horn from the interior, however every boat manufacturer is different
garbageguy
Thanks, SD. I'll be turning the boat around in the slip this weekend so I can get to it from the dock to see exactly what's going on from the exterior of this one. Hopefully I can avoid the gymnastics and digging from the interior
tacx
Most horns have an adjustment screw that will allow you to adjust it. The screw presses against a diaphragm. That may be all you need to do?
