joejiz
Thread starter- Joined
- Jul 24, 2019
- 19
Hi,
I got the boat for free and am getting a replacement engine for it for free. The difference in weight from old engine and newer used engine is new engine is 41 lbs heavier.
Essentially for 10 years a kicker motor mount was installed on back of transom on passenger side. This caused some of the fiberglass to separate which ultimately exposed some of the wood to rain. It appears to be a 2" thick single transom wood piece in this boat from side to side but don't quote me.
Along the transom the fiberglass part of the boat was pulled back due age ever so slightly and finally the drivers side raised transom area is fine because no one hung a kicker motor off that side.
So here we have it. I admit yes there is some water exposure to the wood as seen in the pictures. I've read I can do the following to help me decide to continue:
1 - remove all the old drain plug plastic housings and then inspect around those locations with flash light and small screw driver to see if it is brutally watered.
2 - ball peen hammer the transom and mark where sound changes. ( I've done this and 3/4 of the transom from bottom to top are all sound ). It's only the top 1/4 - which isn't that bad visually, deflection is visible only on top 2" inches going down but that is expected from kicker engine and small rain exposure. ( can create a steel bracket front and back to reinforce )
3 - moisture tester- buy and test
I have heard I can:
1 - buy stainless steel plates and nut and bolt them across the transom to create more strength.
2 - pay some to come and tell me is see wood and say he would never risk his name on saying this if fine and take my $100
What are your thoughts, I've used the boat tons way back when it worked, drove fine, doesn't leak, fun to drive.
I have heard I can:
