David Hard
Thread starter- Joined
- Jun 11, 2019
- 10
so i am restoring this bayliner. the deck has rotted out but the fiberglass is in good shape where and how does one go about cutting out the deck to replace it?
It is a pain. Circular saw set slightly over the thickness of the deck. Exploratory hole to determine that. Cut away from the side 3 inches. I found it is easier to leave a little so when you go to trim that off. A set of adjustable wrenches. You got something to grab onto to twist it up.
Once you dig the foam out from under it you can see what to cut to. Before it is a guess and many have cut right through the hull. Me the extra work is worth it not to damage anything.
