jdvasher
- Joined
- Jul 10, 2019
- 372
Transom finally permanently installed. Looks like it passed inspection by my youngest. I am happy to mention that currently, the boat is his favorite place to hang out.
The supports for the transom cap and bow deck were mahogany. Any tight grain rot resistant wood will work and it also needs to be well sealed.
You're really doing some fine work on your holly and the way things are going here in the forum with lack of participation, I think it's great you're keeping your thread going strong.
Good on you for bringing the next generation of Starmada members into the project.
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"1200","width":"1600","src":"https:\/\/forums.iboats.com\/filedata\/fetch?photoid=10825168"**[/IMG2]
Great work! Even though my project is fiberglass I wanted to commend you on your detailed work and progress. Also for me and hopefully others, seeing progress is inspiring, no matter how different your project may be, thanks for the inspiration!
Buck.
It's best to do the motor install before you put the transom cover supports and cover on otherwise you have to work around and under it.
Do the side seams and keel leak? That's where the gluvit works best, not so much for rivets in the field and especially not leaking rivets that secure ribs as the epoxy can't get between the surfaces.
