ShoestringMariner
Thread starter- Joined
- Apr 18, 2015
- 1,605
Hey guys, you helped me correct the reverse lock my shadetree mechanic botched. Was great last year.
This year, I had the motor off to rebuild the transom. Upon reassembly, reverse lock does not engage. Motor bobs up. The curved shift lever was hard to align and fasten to the the cable end like it was under tension (Wanted to spring back)
I'm sure that I put it all back exactly the same as it was (cable controls.) The tilt pin or rod is in place. But something not right
The only thing that is different is that the motor is on a CMC tilt now.
I found this elsewhere;
But of course I did to make sure eveything looked good before I ran the motor.
What might I have messed up?
You must not shift that motor from neutral to reverse without the propshaft turning or the motor running !
