Having alittle trouble Starting it.idles well once started.New fuel pump.Carb kit installed wires ,plugs replaced points adjusted.Good spark.Would or could the timing of the points opening be off which may cause hard starting?
The motor should have a idle stop so you can pull the rope and the throttle wont back off..Just below where the throttle cable hooks up to the motor there should be a screw with a spring.. It may be a plastic screw..
break it off if need be and replace with bolt and nut like 50% of all others. lol
