- Joined
- Jul 23, 2011
- 53,056
For future reference, never put JB weld on a crack that could be fixed by electric arc welding. It slows the job down greatly because of the clean up involved in getting all the jb weld removed.
a cast iron or cast steel manifold (or block) can be repaired by electric arc welding but you have to get everything clean prior to welding successfully. I prefer to tig weld this material myself but it can also be stick welded or even braze welded with oxygen/acetylene .
Its a 3.0...... Just replace it (they come in the free boats on CL) They crack on the inside and the outside...... Not worth the effort to clean the block enough to attempt to weld
