rakucana@omegafive.net
- Joined
- Aug 20, 2019
- 4
In retrospect, whales tales are for cruising/hole shot, not WOT performance. For that, they are just something else to add to the drag factor. On trim being touchy, bet you look at how much of the tail gets wet at your different WOT trim angles and you'll see the reason. On 6k rpm, I ran a 115 hp 1988 Merc I6 Tower of Power (rated at 5500 max) at 6k every chance I got for 7 years. Sold it to my SIL and last time I checked, many years ago now, he was still running it. It loved rpms.
Once the anti-vent plate ceases to dip down into new water (water flowing out from the transom) you will essentially lose the ability to lift your bow (front of the boat). Trim positions will have minimal affect as compared to having the plate in the fresh water. Any bow lift occurring at-near WOT when set high will depend solely on hull design and thrust angle.
With the AV plate even, you are currently able to dip into that water with the front of the AV plate and have a pronounced effect on it's attitude. With that said, your best bow down configuration is max neg trim....midsection up against the boat transom.......tilt pin removed. Also firewalling the throttle to get past the bad spot as fast as the boat will let you. As you come up on plane and the bow falls, trim out as you go till you get the desired boat "attitude" relative to the speed and water conditions.
