lonewolf41
Thread starter- Joined
- Jun 28, 2013
- 174
SO I got to looking at the data again last night and the MAP voltage stuck out to me. The manual says it should be 1.0-1.5 at idle. Mine was right at 2.0. So I was thinking maybe a bad MAP sensor or vacuum leak. I checked the vacuum at idle and it was 16.0-16.5 in Hg. Seemed a little low, but the manual says 14-19 is normal.
Today I noticed an odd ticking when I bumped the throttle. It was about 3-4 quick ticks in maybe a tenth of a second. It sounds similar to the injector noise, but I unplugged the 2 injectors closest to where I thought it was coming from, but it didn't go away. I have a video that I think you can hear it. https://drive.google.com/open?id=14pcblhahuYiiE0hRDKoSDN7gaiOY-5bV . It is pretty noticeable at 4-5 seconds and about 14-16 seconds.
I may see about a MAP sensor or at least put mine on a vacuum pump ad see what it reads. The buttlerfly on the throttle body was pretty dirty. I cleaned it off, but I wonder if some of that could have gotten to the MAP sensor and is causing issues. It is easy enough to remove that I will probably do that and just see what it looks like and see if I can clean it.
I talked to the local Volvo shop here and they said I had done everything they would do. He did say to lower the oil level some as there was a bulletin about high oil level causing problems so I have done that. I welcome any other suggestions.
Thanks.
Thanks.
