Yamaha 90 pitot tube routing
xjdriver
Hello guys, I am trying to square away my new boat. Found the PO disconnected the pitot tube. One end is under the motor clamped to the upper bracket, other end is inside the cowling it comes out of the wire loom a few inches than ends with a Union fitting. I would like to return to factory set up but not sure where the tube is supposed to run. Thanks for looking. 03 Yamaha 90 2 stroke
xjdriver
Is there a question here?
Yes, I don't know where the tube is supposed to run. Does it go through the lower cowling and come out underneath somewhere, or is it supposed to run from the cable loom straight to the end under the bracket? I'm new to Yamaha and don't want it to look sloppy. I'm going to look through exploded views and see if I can find it.
