New Keel Rollers Shorter than Advertised
ERock82
I just bought 3 new keel rollers that are advertised as 5" with a 5/8" shaft. Here is the link:
https://www.amazon.com/SeaSense-Spool-Polymer-Blend-Roller/dp/B001WAO440/ref=asc_df_B001WAO440/?tag=hyprod-20&linkCode=df0&hvadid=312151608179&hvpos=1o5&hvnetw=g&hvrand=14596004824344934776&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9012102&hvtargid=pla-570635536285&psc=1 - https://www.amazon.com/SeaSense-Spool-Polymer-Blend-Roller/dp/B001WAO440/ref=asc_df_B001WAO440/?tag=hyprod-20&linkCode=df0&hvadid=312151608179&hvpos=1o5&hvnetw=g&hvrand=14596004824344934776&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9012102&hvtargid=pla-570635536285&psc=1
https://www.amazon.com/SeaSense-Spo...ocphy=9012102&hvtargid=pla-570635536285&psc=1
I just received these in the mail and they seem like good quality BUT they are only 4.5 inches wide, not 5. The sticker on all 3 even say 5" x 5/8". WTF? My old rubber ones measure exactly 5 inches and fit the brackets properly. Is this normal? Should I just use with the quarter inch gap on each side or return? I don't want to return if this is normal. Thanks.
There is a possibility that the rollers where miss-marked, but in any case just send the back and look for Attwood 11317
ERock82
I was going to buy that one but it is for a 1/2" diameter shaft and mine is 5/8".
From the link you select 4 or 5 inch and it list the 5 as
Manf. Part # 86283
  • Size: 5"
  • Shaft size: 5/8"
  • Color: Amber
Can contact iboats 800-869-1689 and they might measure
tpenfield
I would kick their ask.
