I was on the lake the other day running my 1995 procraft bass boat. It has the mariner 225 efi outboard. I had run the boat for about 15 minutes and stopped to talk to my buddy who was driving his boat. As I was taking off and about to plane out, the boat slipped out of forward gear. It wouldn't forward or reverse when I put it into gear. so I had someone tow me back into the dock.
However, when I got home, i started the boat and put it into forward and reverse and the propeller works just fine. I don't necessarily hear the lower unit going into gear like Im pretty sure I diid before, but the propeller is spinning in the correct direction when put into forward and reverse.
I emptied the lower unit oil and didnt find any chunks of metal. I also don't hear any grinding when putting the boat into gear. There were some fine metal shavings on the drain plug, but nothing out of the norm. I also pulled off the cowling and it seems the linkage cables are moving the unit into gear like they should.
I cant put the boat back in the water to test it out because I'm currently working on fiberglass repair on the bottom. Is this just a freak accident or should I be looking at other things to diagnose this?
