metsfan3197843
Thread starter- Joined
- May 2, 2011
- 156
I have read that the low pressure pump is not needed and that the engine will run fine on just the high pressure pump. Tracking down a fuel pressure drop to nothing on my engine I discovered a bad connection on the booster pump and it was not coming on. Fixed that and took the boat out and now it runs great. Cruised at 3600 for about 30 minutes with no issues. I have to believe that the booster pump solved my issue but I’m confused on if this pump is just for vapor lock or if it’s needed to feed the suction of the HP pump????
