woodman7975
Thread starter- Joined
- Aug 12, 2008
- 46
I recently replaced the switch plate on my 4.3l Mercruiser. When I went to buy a new one, I guess the old roller ball style had been discontinued and the new plunger type is the only one you can buy now. I installed the new switch plate, reinstalled the control cables and adjusted per the directions on here and the Seloc manual. However when I go into forward from neutral it stalls the engine out most of the time. I looked at the switch and when I put it into forward the switch raises up, but doesn’t come back down to release the plunger, making the engine stall out. Reverse seems to work, or it could be just not working at all, but it won’t stall when going into reverse. Is there a different adjustment or do I need different cables for the new style switch plate? I’m not saying that i did the adjustment correctly but I have done this adjustment before without issues so I do not think it is that. I measured the travel on the cable that comes from the control and I am slightly over 3-1/8”, could that be the issue? The controls worked on the other switch plate though. Any ideas before I start replacing things?
I did also just take apart and regrease the control box, but I double checked that everything was connected correctly and in the right spot after I started having these issues.
this is a 1988 mercruiser 4.3 alpha 1, which the older style Commander controller.
