- Joined
- Jul 23, 2011
- 53,449
in an attempt to restore information lost due to broken links and photobucket.
Here is a thread that will attempt to gather all pertinent generic wiring information
starting with the SAE wiring colors as published by the ABYC
| American Boat and Yacht Council Standards | ||
| COLOR | ITEM | USE |
| Black | Ground | Negative / Neutral Main Return |
| Blue-Stripe | Tilt up and or trim out | Tilt and or trim circuits |
| Brown | Alternator Charge Light | Generator Terminal or Alternator Auxiliary Terminal to Regulator |
| Brown | Generator Armature | Generator Armature to Regulator |
| Brown | Pumps | Circuit Breaker or Switch to Pumps |
| Brown w/Yellow | Bilge Blowers | Circuit Breaker or Switch to Blower |
| Dark Blue | Cabin & Instrument | Circuit Breaker or Switch to Lights |
| Green or Green w/Yellow Stripe | Bonding System | Grounding Wires (if insulated) |
| Green Stripe | Tilt down and/or trim in | Tilt and or trim circuits |
| Grey | Navigation Lights | Circuit Breaker or Switch to Lights |
| Grey | Tachometer | Tachometer Sender to Gauge |
| Lt. Blue | Oil Pressure | Oil Pressure Sender to Gauge |
| Orange | Accessory Feed | Ammeter to Alternator or Generator |
| Orange | Common Feed | Distribution Panel to Accessory Switch |
| Orange | Feed | Accessory Circuit Breakers or Switches |
| Pink | Fuel Gauge | Fuel Gauge Sender to Gauge |
| Purple | Ignition | Ignition Switch to Coil & Electrical Instrument |
| Purple | Instrument Feed | Distribution Panel Electrical Instruments |
| Red | Instrument Feed | Distribution Panel to Electrical Instruments |
| Red | Power Feeds | Positive Main Power (particularly un-fused) |
| Tan | Water temperature | Water temperature sender to gauge |
| Yellow | Generator Field | Generator to Regulator Field Terminal |
| Yellow | Ground | Negative / Neutral Main Return |
| Yellow w/Red | Starting Circuit | Starting Switch to Solenoid |
