Bgbbgb246
Thread starter- Joined
- Jan 28, 2019
- 38
I recently re-powered my 19-ft Fisher shallow v bass boat with its maximum horsepower of 150 horsepower. On the first test drive I quickly realized that I would have to remove my 10" jack plate as the boat sat very unlevel. (I know the ridiculously big Jack plate to try to use on the maximum horsepower engine. I wasn't really thinking) After removing the jack plate and mounting the engine straight to the boat The boat sat pretty much th same way in the water as it did with the 115 horsepower with a jack plate. The only noticeal difference now is that at speeds after putting speed and before plane, the bow of the boat comes up in the air quite a bit further than it used to and remains there until on plane. It's not really something I can't live with but it cuts out a bit of my visibility and sometimes you just have to travel at that slow speed in channels and shallow areas. I understand this may end up just being a give and take where I get the top speed that I want but with a few trade-offs. I cirtainly prefer the extra 12 mph. However, I was thinking of some possible solutions to my issue and one of my thoughts was reducing the weight in the rear end of the boat. It has a 39 gallon tank that probably weighs about 230 lb full. Obviously I can't really move that and also it's designed intelegently to to put a lot of the fuel behind the bench seat instead of by the transom. But what I can move is the three large 12 volt batteries that sit right against the transom; 2 on one side and one on the other. I have a compartment that I never use it's about 3 ft behind from the very front of a boat. It's big enough to fit all three batteries. now I figure these three batteries probably way a combine total of 120 to 150 lb and I think moving them this far forward may help even out the distribution of weight in the boat and make up for the added weight of the bigger engine. The wiring from the trolling motors should be pretty easy routing as the trolling motor is just right there. Running the leads from the motor to the front of the boat will be a little bit of a job but something I'm willing to do. what do you guys think? Do you think this amount of weight all the way at the front of the boat will even the boat back out, or do you think it's not worth the effort.
