Sylva-Ranger
Thread starter- Joined
- Jan 17, 2016
- 167
I made this device for testing voltage on outboard ignition system.
Like in this vidéo ( in french) , i can mesure whit my DVA the stator , triggers and Switchbox voltage on my driveway or on the lake. This is for troubleshooting purpose.
https://www.youtube.com/watch?time_continue=37&v=BErZyDhmjzo
Do you think i can use the htz fonction on my multimeter, to compare the reading of the different cylinders in the coils primaries ?
Whit my DVA i can mesure the voltage at the primary of each coil , , but i also whant to compare the number of ignition in the primary of each coi, l to ensure they receive the same a their primaries…..
In the vieo, as you can see the no 2 clylinder receive less voltage than the 2 others, but i whant to mesure the number of ignition for each, like an tachometer
Sorry for the bad English , i tri to explain the best i can …...
