Building a '93 Caravelle 1750 Classic Bowrider
Reserector_
Chief Petty Officer" & 2021 Splash of the Year Win
I fell Thursday night while roller skating. Pretty sure I fractured my wrist. Between that and days of cold and rain, I didn't think I would get anything done this week. With extra days off for Christmas, I was losing time that I should have been gaining.
But if I've learned anything in my 56 years, it is that my plans are seldom the plan that gets approved, if you know what I mean. So in times like this, you roll with it and wait to see how things shake out.
We'll things shook out today. It was perfect weather for pouring flotation foam in the boat, so that's what I did.
It was stressful and fun at the same time.
I pre-warmed the liquid in the cab of my truck, which was in the sun.
I made my holes big enough to stick a blow dryer in. That's how i pre-heated the hull and floor.
The extra warming made the foam kick off big and fluffy. I was thrilled with the expansion. One 4 gallon kit is enough! I have two small places yet to do once the cap is on, and there is enough left to do those.
Photos are in reverse chronological order, and I'm tired. So please scroll to the bottom and work your way up.
kcassells
Looks Great! Sorry to hear bout da wrist. Roller skating???? Time to put those bad boys back in the closet.
Yea I got a kick out of pouring the foam.
Have a Great Christmas!
Reserector_
Not much boat progress this weekend, but progress nonetheless. At least I finally got a haircut...and picked up a small tractor that I was supposed to get last spring.
I used a soft wire cup wheel and a belt sander to clean the floor and tabbing of stray foam.
Used a router to clean out the foam holes, sealed them with resin, and then plugged them with peanut butter and the plywood plugs. Just need to slick them off with the belt sander before glassing the floor.
The holes in the flotation boxes were ground flush with the belt sander and sealed with csm.
I removed the gimbal housing again and finished sealing the opening with csm. Did some other little finish items.
Next: glass the floor. Hoping to do this on New Years Day.
froggy1150
Something I stumbled across when I was doing my deck. When I glued the pucks in I had minute pinholes around the edge in a spot or two . Very small. When I started laying deck glass I got big bubbles that I couldn't get rid of. Thank God I started on the smaller piece. Went back and coated the rest with resin pushing it in all the crevasses. Don't know if it was a reaction or just air from the heat but didn't happen after.
Reserector_
Thanks for that. I already dribbled some resin in a few pinholes. There's a good chance there will be more after I belt sand them. I'll be sure to seal them before I go to the next step.
I need to lay it into the joints as well.
tpenfield
This makes me think the the 2-part foam ‘out gases’ for a few days after it is poured. Something to keep in mind during the rebuild.
Reserector_
I had given a lot of thought to cutting tapered holes with the jigsaw set at 30° or more. Might have been tricky drilling the starting hole, but a tapered plug cannot fall into its hole, and better yet, would be easier to set back in place with PB.
The problem with the straight plugs is keeping the PB spread evenly on the sides where you need it. That, and sealing the pilot hole in the middle.
Thought about it. Didn't do it. :(
kcassells
Millions of ways to do it. I think your approach was right on the money.
Oh....thats what I did lol.!
Reserector_
The weather was good enough to roll out some resin, but I had to be sure to hit my window or it would be too cold.
I sanded down the plugs, vacuumed the floor and pre-cut my 1708. That's when I realized I was not going to have enough 1708. However, it was enough to make a serious dent in the project. So I hit my marks and did what I could. I ran out of cloth and resin at the same time. (9 gallons so far.)
Here are some pictures from today.
Reserector_
You know it! The only thing that has any "give" is the sides where it will join the cap. It is a loooog way from where I started.
Reserector_
Still waiting for cloth and resin, so I guess I will start removing rotten wood from the underside of the cap tomorrow.
All I did today was install the firring strips along the edges of the hull.
Original was 1" wide strips of 5/8" plywood. I decided to use 1 1/2" x 3/4" PVC on edge. These come in 12' lengths. The ss screws bite easily and grip tightly. PVC curves smoothly without relief cuts, and will not crack or split. Can't rot, either.
This might be a good place to attach my wiring and control cables to when I get to that point.
kcassells
Neat application. Looking good. What if any adhesive will you use to secure cap to pvc?
Reserector_
The cap fits over the hull "shoebox style". Screws will then go through the edge of the cap, through the edge of the hull, and into the pvc. The pvc is just there for the screws to bite into.
Currently, it is only screwed in enough to hold it in position.
I plan to get a bead of sealant between the cap and the hull. That will seal the overlap as well as make the joint more solid.
