Step by step for the winterization for the boat engine of mercruiser 2.5L 1989
liusigou
Do you have step by step for the engine of mercruiser 2.5L? Thank you
Starcraft5834
yeah. step is to drain out the water from the block and manifold. air doesnt freeze on earth...
Tycer
Thank Tycer for your replying. I have a question for the oil change. Which hole should I use to extract the old oil? There are two holes , one can adding oil , the other is the level ?
Outdrive top hole is a vent. Bottom is drain and fill.
Dipstick for oil drain.
