Jim Hawkins
Thread starter- Joined
- Mar 11, 2013
- 515
The boat is a Nautico catamaran and the deck is spongy and needing replacement. BUT the main reason I want to redo flotation is that this boat sits in the canal and every time we get a heavy rain I worry about the bilges and whether the boat will be floating when I get back to it.
The twin hulls are not completely filled with foam and as is common with some old cats they fill with water. Down inside each hull is a bilge pump and a third one on top of the deck. I want to redo the deck to eliminate the plywood, fill the hulls with high density foam, use one topside bilge and glass directly on top of the foam. I glassed on top of foam on another boat 10+ years ago and it's holding up great.
My plan is to cut down on the amount of foam I will need by filling each cavity with those nearly indestructible bounce house balls and then let the foam fill the voids around them.
The boats in the following pics are not mine but stuff I pulled off the net, perhaps even from someone in this forum.
The boat with the empty hull is identical to my cat. So, anybody done anything like this?
