PensacolaJason
Thread starter- Joined
- Oct 23, 2011
- 176
I just started having an issue with my outboard 1996 130hp Evinrude not wanting to tilt up on occasion. Sometimes it will tilt up and then if I release the switch and try pressing it again it does nothing. It always tilts down without any issues, but not up. I checked the hydraulic fluid and it’s full. I also made sure the battery was fully charged and tested both the trim switches on the console and outboard itself. I’m thinking this is a relay issue. I tried removing one relay at a time and then trying both up and down, but neither work when just one is removed, no matter which one I remove. I also swapped the relays and still just tilting down worked. My question is if I am barking up the right tree. Does this issue sound like a bad relay? If so, does this motor require both to be plugged in for up and down to work? What other things could I check when just tilting up doesn’t work consistently?
