harringtondav
- Joined
- May 26, 2018
- 2,520
I believe good maintenance, syn engine oil, and good driving habits will keep any engine and drive train alive for a long time...well over 200K mi. I've retired two 21 yr old vehicles. E Iowa salt rust took them out, but their guts were still good. Good enough to resell.
I'll use the same driving habits with my 2.3 turbo. Pedal off up shift to prolong the clutch packs. Under towing load the same, shift under 25K for the first two shifts +- 25 mph, then manual/paddle shift with moderate/meaningful acceleration at around 3200-3500 rpm until at cruising speed. Piston rings like lower rpm and higher pressures to do their work, especially at break in.
I've got some very steep grades getting into and out of our river home. The 5.2 V8 Durango went to 2nd gear and 4K to make it's way up. I'll report back in April/May to compare the Ranger's little turbo.
