Shade Tree boy
Thread starter- Joined
- Aug 22, 2011
- 46
Have had this problem for the last few years and still don't know where the leak is coming from. Any ideas on how to isolate the leaky component?
Never said what motor
Remove the cooling hose from the cooler and see if fluid is found. It can be tested by applying air pressure to the oil side, try 25 psi
I've heard that the power steering actuator seals on these sometimes leak, and while V/P never released a kit to repair them, someone on here figured out a way to replace the seals that cause the leak. Its way back behind the engine on the starboard side of the transom mount.
All Dodge..I removed the entire oil cooler from the engine and tested with pressure per your instructions. I cant identify any leaks. The part looks pretty good. No significant corrosion. Before I re-install this part do you think my local boat shop could test it to be certain the part is good?
Lou C..I read about this too. After close inspection, I can find no evidence of leaks at the actuator. Everything is clean and dry back there.
Clean the engine/bilge pretty good. Lay white oilsorbs or a white sheet in there, run a bit and see where the drips are. Follow them to the leak. I'm betting the lines or pump.
