Hi, probably a much asked question but I've been using a 15hp 2 stroke on my 3.8m Bombard inflatable. Its Ok but I guess I would prefer something a bit less noisy /messy and that would be more likely tick over without stalling!
Im looking at s/h 4 stroke motors but my current motor (Johnson 2 stroke) is around 35kg (77lbs) and the 4 stroke replacement would be aroung 52kg (114lbs). I cant get to try the 4 stroke on the water so I'm asking if its common to put a 15hp four stroke on a 3.8m inflatable without having to sit way forward for the best trim when in the inflatable alone.
Also is 52kg an easy lift for one person? it seems heavy?
Thanks
Thanks
