8RG2018 is the voltage regulator number, not the alternator. Look for the number 8MR2023F or MR2036K. Should be on the flat section of the frame that forms the top mounting.
That's correct.
The inherent design of an alternator is self limiting. It will only ever put out it's maximum rated current. It can't exceed that. Unlike the old DC generators which could, would and did, exhibit a rapid and high kinetic disassembly if the output current regulator wasn't see correctly.
Many years ago I was doing a long drive at night (over 450 kilometers). The car's alternator was a 35A unit, and I was running a couple of high powered spotlights (Cibie SuperOscars)... It didn't take long before the lights started to go quite yellow.
The alternator was outputting its full 35A, but with the vehicle's standard headlights and the spots, it just couldn't keep up... Point being that the alternator didn't 'make poopies in its pants'....(Also at the end of that trip, the fuel gauge was worryingly close to the bottom of the scale, and it was 1984, no 24 hour petrol shops in those days, especially along a not often used country road.. :facepalm: I had already put a 20l can of petrol in part way down too, as I knew it was going to be a close thing..)
Chris..........
