Very loud rattling/knocking noise under load
Rick Stephens
Does it look like the chine was glassed on over the completed hull? THat's what it looks like in the pic. From what I have seen, chines are usually built right into the mold for the hull, so it seems strange. If it was molded into the hull bottom you have a serious problem and probably the stringers are mud.
tank1949
I should add that I live at 7+k elevation. So the compression numbers are lower then what they would be at sea level.
Unless you run it hot or wore it out, I'd check compression tool. You may have shraider valve sticking or not working at all. I almost pulled a 350 because of poor numbers. By chance I discovered loose valve. I don't know how it got loose. I tighten and retested all 8 cylinders to 150 +-5 lbs. I don't know about elevation factors???
JASinIL2006
From other pics the OP posted in the Resto forum, her has serious cracking in other places, not just along that chine. I'd be amazed if he doesn't have substantial rot in the boat's bones.
cruiser83
Just thought I update on the noise. Pulled the motor which turned out to be a zz4 or L31 motor. They used the wrong coupler, it had the big triangle coupler and cut the relief squares out of the flywheel cover so that allowed the coupler arms to hit the y pipe. That's the loud klacking noise
garbageguy
considering there's evidence of hull problems, is it possible that a flexing transom could be causing the movement and resulting noises? just spit-balling
cruiser83
True, but the transoms was recently done I think. It's very solid. And the wood doesn't look bad.
tank1949
You have 14" flywheel? Most 350s do. Many triangle shaped couplers are for Alpha but they work on Bravos, at least mine do. Cut reliefs on bellhousing may indicate they didn't have correct bellhousing or something came loose and ate insides? Hit Y-Pipe????? That doesn't make sense, but few things do anymore. LOL and good luck!
Scott06
Sounds like they used a 14” flywheel with a older generation flywheel cover and clearanced it to fit. You can buy a 12&3/4” flywheel and correct coupler with I think should work with your older model flywheel cover. This flywheel cover also has narrower rear engine mounts to work with your transom housing.
Bondo may know more about the particulars
tank1949
I think you may something! I have some smaller 305 flywheels in my shop, but I cannot remember bellhousings being smaller for 305 vs 350s? But, I am getting old. Former owners may have swapped straight drive parts for I/O parts. Now, current owner has a monkey-f! I've been burned too! This scenario is why no one touches my boat but me.
most likely a 168 tooth flywheel in a 153 tooth flywheel cover
buy a new flywheel if you dont have the correct one. they are under $80. about $125 for an SFI approved one.
tank1949
I am trying to wrap my head around stuff slicing into y-pipes? I've owned Alphas beginning 1986 year and now Bravos. If my old memory serves me correctly Alpha and Bravo Chevy v8 bellhousings (flywheel cover) motor mounts fit Alpha or Bravo inner transom plate motor mounts. Maybe I was just lucky? I learn something new every day!!!
the flywheel for the balance shaft V6 and V8 should be the same your choice is either the 153 tooth or the 168 tooth.
the starters are either for 153 tooth flywheel (straight across) or 168 tooth flywheel (staggered). then there are the direct drive and the PMGR.... there is no "v8 starter" they are the same starter no mater if its a 3.0 or an 8.2 (other than style and spread)..... GM is easy that way.
