Captain Caveman
- Joined
- Mar 1, 2005
- 1,067
This sounds like a 7-minute abs commercial
I think the description tells the issue to a "T".
I put a foil on about 40 years ago, when they were first invented, and have had one on every boat I have owned since then. Makes sliced bread look like old news.
I just spent 50 grand on a brand spanking new boat and it performed awesomely well. Put a fin on anyway, just because, and the improvement in performance, top speed, hole shot and prop slip would make anyone want one as well.
Never had a broken anti-ventilation plate, never picked up weeds or debris and ran successfully over 50 boat years.
First I’ve known of one to improve top speed. How does that work ?
i can understand their use in the tiny percentage of situations with small engines and needing help staying on plane...but other than that they are dreadful things and usually only comprising a poorly set up rig or underpowered boat. Any I’ve known of always have a negative effect on top speed. Always.
Well you would be wrong in my circumstance.
Have you tried it with it off ? Just a thought. Not sure of the science behind it making it faster to be honest.
I have to ask do you read what was posted or do you just wait to post. I never said I added the foil to gain any speed, I used the boat several times last summer before I put the foil on last week.
X2
I bought my outboard with a StingRay Jr installed. Boat planed quick and had good top end speed, for a 14' jon boat and 7.5HP outboard. After reading about how junky the hydrofoils were, ruining speed and handling, I ripped it off. Be gone snake oil fin!
Well..... My next trip out ,the boat was a dog out of the hole and top end speed was reduced due to a bow-up attitude... Needless to say, I put that junky fin back on the outboard and the great performance returned.
Yes, they may not be right for every boat, but they do work as advertised. Would I put one on my 18'er with a 140HP Mercruiser.. Nah....
You’ve literally just given an exact example of the type of boat I was referring to. Haha.
Although I don't quite have your years of experience, my tale is much the opposite. I've ripped off at least 5 fins (refuse to call them foils, they are not) on various used boats I've boat over the years. Some performed better without it and the owner just thought they needed it, some boats ended up with smarttabs installed instead of fins, and my experience has been night and day with tabs vs fins. My only use case so far for a fin has been an underpowered tinny that should have had less weight and a bigger engine. The fin was a band aide for the lack of seahorses.
