Appleo's 1985 Starcraft Supersport 18 foot - Restoration 2019/2020
classiccat
Man, you're rippin' through this build!
You're not the 1st person to salvage the original paint from these 80's starcrafts. Well done! :thumb:
fetch
Glen (Dozer) saved a similar-era 201SS a few years back.
appleo
Wanted a livewell for this boat. original had none
Found a few on craigslist and settled on a 30 gallon beauty
Had to patch prior owners holes with 3m 520 and aluminum scrap plates
Installed a used bilge pump as a pumpout pump
Found brass fittings in the form of rain barrel
connection hoses. Check out the photos
Livewell exterior singed with that Interlux 2 coats roll on
lid made from Advantec covered with matching floor vinyl Nautolex
Hatch Door was from ebay 44 bucks
Stainless lid bolts .
Ready to connect to boat via common garden hose fittings
Hope i can fill it with fish
Photos to follow below
appleo
Lovewell photos more
appleo
Next task the bow fishing area
Keep the original layout. and pedestal mount in the floor? Cubbies holes for storage access
Or cover with a full bow deck and install pedestal mount on top the deck? Hatches for storage access....
Thoughts? Pros and cons?
oldrem
I opted for raised deck, but not up to bow level. Don't trust these old legs up that high lol. Still gave me decent storage underneath.
appleo
Livewell to be mounted rear of passenger chair. So I Needed something rear of captain chair
Decided on storage box
Leftover oak flooring, plywood, 6x8 poly carpet from home depot
Piano hinge, $2.00 soffit vent for air circulation , Antiskid strip on top
Sized similiar to livewell
appleo
Lol. was told piano hinges should be hidden. so i took apart the box and adjusted
appleo
Finished the rear glovebox. transom trim. Nautolex and Marine vinyl. Glovebox door cherry plywood scrap.
A little different than original.
Watermann
You've got your thread here in the general reso section, makes it a bit tougher for us SC tin heads to find.
Looking good so far :thumb:
appleo
Wanted to add some support to front center floor not much there originally with wrap around seats
Used some shower door aluminum channel and a few aluminum mudflaps
Same raw material at the local supply house would have been 35 dollars.
appleo
Was a single center upright rib that fell short of the bow by about 3 feet.
Looking to beef that framework up in case i add a pedestal seat base
appleo
a see attached for original configuration.....l
Watermann
Oh I see, you're talking about the very bottom most deck rather than the elevated next level where in the stock SS it's a bow rider seat.
appleo
Bow deck fabricated and laid in today. snow forecasted for upstate New York
appleo
Hatches on order Similar to live well lid
Have Front Seat base
Will dry fit first before drilling
Bolts vs screws
trolling battery to reside under bow deck port side. helps balance the boat vs chubby captain 😃
