j_k_bisson
Thread starter- Joined
- Oct 6, 2010
- 1,082
I recently acquired a 1988 Johnson 4 hp Sailmaster (J4RLCCS) that is in near mint condition. I have purchased a factory service manual and have rebuilt the Fuel Pump, Carb, primer/choke system and installed a impeller rebuild kit. I can get it to run great at both Idle and High RPM's.
My issue is with the timing/carb settings seeing the throttle is on the top of the motor and the carb settings for the idle speed jet on the front. I have read all the service manual and cannot find the idle jet pre-setting. I want to confirm this setting before running for a long time, so I do not run it too lean.
What is the idle jet setting for this motor. It is referred to as the "4 hp Ultra" in the service manual.
I'm hoping someone can put me in touch with where i can get the original operators manual for this motor. There has to be directions on how to run this. Any and all help welcome.
