Westieman
- Joined
- Sep 15, 2019
- 86
Thanks Scott for the advise, thanks Lou for the compliment!
Well, it is not easy to get it right the first time. I misplaced the shift cable. The cable should pass behind the power steering. Luckily it is an easy fix. Problem is that a lot was already disconnected by the previous owner. And of course, my short term memory is no longer like it used to be. I must be getting older.
Anyway, I will get there, eventually
Tomorrow I have a special project on the boat! I will show you guys when it is done.... curious? :lol:
I hope I will not need to adjust the alignment of the engine. Position of the engine mounts did not change since I took the bolts out of mounts on the engine side. Of course, the rubber mounts might have been compressed over time due to the weight of the engine. I will check it though.
Hope you had some fun out on the water Lou, to compensate for the struggle in your car's back door. It is great you can do those repairs with the help of your son. These small things mean a lot to me, and to you I guess?
Stay safe!
greetings from the Westieman!
Stay safe!
