Symptoms of a damaged or missing High Speed nozzle gasket in carb
Newyota
If the high speed nozzle gasket in carb becomes damaged and or missing what would be the symptoms one might experience?Would you lose suction of nozzle since you would have the two castings tring to butt up to each other but not sealing?
boobie
Yes, got a model # ?? Motor would want to die at WOT.
F_R
As boobie suggested, it depends somewhat on the model we are talking about.
kbait
Leaky/missing nozzle gasket will permit unmetered fuel through high speed fixed jet/needle valve (depending on year). Suspect that gasket - if it runs rich at higher than idle speed with fixed jet, or - on adjustable needle setup, if motor keeps running at any throttle setting with high speed needle turned all the way in.
Newyota
E30RCCE is model.Most likely the gasket in this case by the looks of things..Engine just bogs down badley and not die completely.
Newyota
Carb kit installed and out running the river. Issue resolved. Sure it was the high speed needle/tube gasket.
