LargemouthBass21
Thread starter- Joined
- Sep 29, 2018
- 207
I put my 3hp Yachtwin back together today, and timed the ignition with a multimeter. The spark is bright blue/purple and snapping. Took a bunch of pulls (6) to start it at first as the bowl was empty and it was at an angle but once it ran for a bit it could start first pull. It’s 36 degrees out and the barrel it was running in had ice on top of it (also hadn’t run in a week). Sometimes I needed to have the choke on to start it (but I could turn right off after and it’d stay running fine). When reassembling the magneto I noticed the points don’t completely contact each other fully if that makes sense (almost like they’re worn) but reinstalled anyway. Could this end up being a problem? Has good snapping spark and seems to start fine but is it bad I used the old points (not taking back apart until I have a failure). Would an air silencer help with cold starts? Mine is missing it and needs one, I read they keep it in a partial choke condition and helps it run better. Overall I’m glad to be (hopefully?) done working on the motor and am looking forward to taking it out on the water. Thanks guys for the help!
EDIT forgot to add I had a big scare with torquing the flywheel, I’ve been using my fathers tools and he decided to keep a broken torque wrench right next to his good one. I grabbed the bad one and kept tightening and tightening but no click. Luckily I realized before I did any damage lol
