Scott06
- Joined
- Apr 20, 2014
- 6,744
But I'm talking about an I/O, hence it being in the I/O section
In my particular case, a carbed 3.0.
Generally speaking, running relatively high octane fuel, in relatively low compression motors, is not advised. Mainly because the spark, without the extra compression, sometimes isn't enough to ignite the fuel.
When an engine calls for higher octane fuel it is because the compression ratio is higher and or the ignition advance is greater and the engine will be more prone to ping /detonate / preignition which left unchecked will severely damage an engine. There is no harm nor ill effect running 91 or 93 in and engine that calls for 87, fuel will ignite just fine if the engine is in good working order. Only your wallet will empty faster...
on the original 3.0 pump mounter filter this will in the same way as other filters separate water , on my 1990 that the original ceramic element was in for many years, the spring on the bottom was rusty from water accumulating there.
